HamishNZ
E34 525i Shift selector cable jamming
I've removed the cable from the selector lever.
The lever moves fine, however the cable seems to be really clogged up.
It becomes stiffer the more you retract/extend the cable (closer you get to P) and won't go into P as I don't want to put any more force into it.
Any ideas? I'll give it a spray with WD-40 and see what that does.
The cable may have been connected to the wrong side of the selector lever so may be a little bent? Doesn't appear to be bent though, would that stuff it?
Would my selector cable from my wrecked 94 e34 525i with ZF 5HP-18 trans fit my 93 525i Jatco A5S 300J trans?
