beemn
E61 N52 idle
Anyone know what the idle should be for the N52 3.0?...searched but cant find the answer?
Edited by beemn
not a thing
Mine is around 800 rpm from memory.
I actually paid attention today and it's actually around 600 rpm.
I have a slight vibration, which is only at idle, 3 things that are obvious are engine mounts, low idle, and this bmw_SI_B18_02_08 (1).pdf
I have a slight vibration, which is only at idle, 3 things that are obvious are engine mounts, low idle, and this attachicon.gifbmw_SI_B18_02_08 (1).pdf
That PDF is interesting, as mine makes an odd noise sometimes at the lights when it's up to temperature - I thought it was maybe a small exhaust leak but the vibration mentioned in the article is probably more likely the cause. It doesn't happen often enough for me to do anything about it, but I'll probably start listening out for it more now!
