beemn 50 Report post Posted May 20, 2014 (edited) Anyone know what the idle should be for the N52 3.0?...searched but cant find the answer? Edited May 20, 2014 by beemn Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 20, 2014 Nothing in the owners manual? Quote Share this post Link to post Share on other sites
beemn 50 Report post Posted May 20, 2014 not a thing Quote Share this post Link to post Share on other sites
RustyItalian 11 Report post Posted May 20, 2014 Mine is around 800 rpm from memory. Quote Share this post Link to post Share on other sites
RustyItalian 11 Report post Posted May 23, 2014 Mine is around 800 rpm from memory. I actually paid attention today and it's actually around 600 rpm. Quote Share this post Link to post Share on other sites
beemn 50 Report post Posted May 23, 2014 I have a slight vibration, which is only at idle, 3 things that are obvious are engine mounts, low idle, and this bmw_SI_B18_02_08 (1).pdf Quote Share this post Link to post Share on other sites
NakiTouring 54 Report post Posted June 1, 2014 I have a slight vibration, which is only at idle, 3 things that are obvious are engine mounts, low idle, and this bmw_SI_B18_02_08 (1).pdf That PDF is interesting, as mine makes an odd noise sometimes at the lights when it's up to temperature - I thought it was maybe a small exhaust leak but the vibration mentioned in the article is probably more likely the cause. It doesn't happen often enough for me to do anything about it, but I'll probably start listening out for it more now! Quote Share this post Link to post Share on other sites
