rarerimresource 6 Report post Posted June 17, 2014 After a 260/5 with an M20 bolt pattern. The serial number for the box will have either TNN or HM around the edge of the bell housing, as distinct from the more usual 260 which will have NW, ANB or TNW. Cheers. Quote Share this post Link to post Share on other sites
Paragon 14 Report post Posted June 17, 2014 What is the significance of these codes - before I go and try an read mine. Quote Share this post Link to post Share on other sites
rarerimresource 6 Report post Posted June 18, 2014 (edited) Close ratio G260. You can check your option sheet for it if you've got it, option 206 - probably easier than checking under the car. Edited June 18, 2014 by rarerimresource Quote Share this post Link to post Share on other sites
Paragon 14 Report post Posted June 18, 2014 The one manual car I have does not have the original gearbox in it. One spare gearbox I have is stamped ending NZ - any idea what that is ? Quote Share this post Link to post Share on other sites
