bmwsparkle
LSD diff ratio change
Have a 3.46 sitting in my garage, and the 3.07LSD in the car atm, does the 3.46 crown wheel and pinion swap straight over, no modifications needed? Has anyone actually done it?
cheers
cheers
If they are the same sized diff it should be a straight swap of the LSD centre from one to the other. So assuming you have 2x 188's or 210's and not one of each.
Just don't loose or muddle-up any of the preload shims from the side bearings, and leave the pinnion alone!!!
SRBMW has done it before I believe.
how do i tell if its 188/210 again glenn?
do i swap the crown wheel and pinion from the 3.46 into the LSD or swap the LSD centre into the 3.46?
Behind the stub axles (6 allen bolts for the CV's) there are the side flanges, a 188 has 6 bolts and the 210 has 8 holding them on. and a 210 "looks" bigger than a 188.
This is a 210, also note the drain on the side, not the back.
Edited by E30-323ti
