beeker
E36 removing ABS
I have a 1994 E36 M3 3.0 tarmac rally car and want to remove the ABS.
I'm told all that is needed is to remove the ABS fuse and relay.
However... I have removed the ABS controller/ECU instead (was in the way of the cage, so why refit?), and after a test drive the car appears to drive ok including rev'ing to ~7k redline (speed sensor requirement concern).
Is this a legit way to disable the ABS?
Any other negatives?
