tima 5 Report post Posted October 27, 2014 Hi, My e39 540 fuel gauge has stopped working correctly. Started to only report half of what was in there and now i removed the battery to see if it would work and doesn't report any at all. Any suggestions? Cheers Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted October 27, 2014 Go into the obc hidden functions and view fuel level. Google how to access it. Should show readout from each of the two senders. See if one reads zero. If its reading half it makes sense that one sender has failed. Quote Share this post Link to post Share on other sites
tima 5 Report post Posted October 27, 2014 (edited) Edited October 27, 2014 by tima Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted October 27, 2014 yup bad sender. guessing its the right hand one. heres a guide to removing. http://www.pelicanparts.com/BMW/techarticles/BMW-5-Series-E39/82-FUEL-Fuel_Pump_Sender_Removal/82-FUEL-Fuel_Pump_Sender_Removal.htmpulling the plugs out should reveal if the sender has an break or if the wiring is buggered. not sure if they are fixable or just need replacement Quote Share this post Link to post Share on other sites
tima 5 Report post Posted October 27, 2014 yup bad sender. guessing its the right hand one. heres a guide to removing. http://www.pelicanparts.com/BMW/techarticles/BMW-5-Series-E39/82-FUEL-Fuel_Pump_Sender_Removal/82-FUEL-Fuel_Pump_Sender_Removal.htm pulling the plugs out should reveal if the sender has an break or if the wiring is buggered. not sure if they are fixable or just need replacement Ill pull it out and give it a good shake about and see what happens. Strange it decides now its time and then both die.. Quote Share this post Link to post Share on other sites
tima 5 Report post Posted October 28, 2014 Update. I pulled the battery out and now it says its 100% empty but still reads 31l on the left like it said on the OBC. Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted October 28, 2014 The dash readout are sometimes delayed from.actual readings to stop fast changes. When i changed my outside thermometer it took two days to go from negative 60 up to actual temp. Though hidden functions showed it straight away. Quote Share this post Link to post Share on other sites
