Guest Andrew
e30 people with roll cages
Guest Andrew
Where did you put the fuse/relay box after the roll cage bar comes onto the front strut - it will fit squeezed in diagonally - but it looks kinda ugly.
Pics would be cool.
On the last two cars that Herbert did, you could fit the fusebox almost in the original position, needed to move it sideways about 10-20 mm, but otherwise went in okay. If your forward running strut tower bars are in a slightly different posi, then it sounds like you will have some problems getting it to look tidy.will cutting away the lower part of the fusebox, and making an ali panel to cover the hole in help?
I see what you mean. The tube that attaches to your shock tower is a good 40-50mm further inboard than mine were, so you are probably going to have to do some surgery on the fusebox to get it to fit, or try moving it as you suggested.
Hey My friend who wired my car cut the loom and reconnected it inside my glovebox using big 20way?? male/female connectors from dicksmiths.theres a billion wires so take your time and write colour that are the same down on a bit of paper
Guest Andrew
I think i'll cut down the box - probably just take out that corner and it will fit. I wonder why my bar attaches in a different place?
Because nobody (at Herberts) took pictures or made notes of the last cage they built!
