Guest Andrew Report post Posted November 14, 2005 Where did you put the fuse/relay box after the roll cage bar comes onto the front strut - it will fit squeezed in diagonally - but it looks kinda ugly. Pics would be cool. Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted November 14, 2005 On the last two cars that Herbert did, you could fit the fusebox almost in the original position, needed to move it sideways about 10-20 mm, but otherwise went in okay. If your forward running strut tower bars are in a slightly different posi, then it sounds like you will have some problems getting it to look tidy.will cutting away the lower part of the fusebox, and making an ali panel to cover the hole in help? Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted November 14, 2005 horrible phone cam pic to show what i mean Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted November 15, 2005 I see what you mean. The tube that attaches to your shock tower is a good 40-50mm further inboard than mine were, so you are probably going to have to do some surgery on the fusebox to get it to fit, or try moving it as you suggested. Quote Share this post Link to post Share on other sites
SRBMW 6 Report post Posted November 15, 2005 Hey My friend who wired my car cut the loom and reconnected it inside my glovebox using big 20way?? male/female connectors from dicksmiths.theres a billion wires so take your time and write colour that are the same down on a bit of paper Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted November 15, 2005 I think i'll cut down the box - probably just take out that corner and it will fit. I wonder why my bar attaches in a different place? Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted November 16, 2005 I wonder why my bar attaches in a different place? Because nobody (at Herberts) took pictures or made notes of the last cage they built! Quote Share this post Link to post Share on other sites
