timewarrior
Oil change E30 M50B25 swap
Hi all, I'm doing my first oil change on my E30. Can someone who's done the M50B25 swap advise me on which oil filter to use? Is it the E36 M50B25 or the E39 M50B25? And is it a different filter if you have a Vanos equipped engine? The Ryco book here at SCA isn't that helpful. Cheers
If yours is an e36 donk it should have a metal cap with a bolt through and use a R2582p
If its an e39 it should have a plastic cap and use a R2592P
