exige92
Trans fluid cooler
Hello
I have a 1997 e39 540 nz New
After the trans cooler that sandwiched between radiator and air-con condenser.
I guess since I have it apart I could be keen to replace the power steering unit at the same time. (although this appears to be in good condition)
only other part I need is the little nipple that connects the pipe from the radiator reservoir to top left hand side of radiator. I'll try find the part number asap.
Vent Hose Fitting on Radiator for BMW. # 17110419132
Part numbers of the trans cooler 17.22-1740798.0
the power steering 32.41-1 141 819.0
as below (not my pic but same as)
anyway where is best to get these off new i think will be best....if you can supply these call me 0211543092 thanks Liam
Edited by exige92
