fred_ 166 Report post Posted December 14, 2014 I've had this lying around and never got round to installing. This suits 2008+ E9X Manual M3's. It cost around $600 landed from the states. $400 or nearest offer takes it. Exert from Turner: "Get MORE HORSEPOWER and TORQUE on your 2008, 2009 and newer M3 coupe, sedan or convertible by replacing the stock crank pulley with this specially designed performance version. The Power Pulley reduces rotational mass and safely under drives your belt driven auxiliaries for reduced parasitic power loss. The end result: More power to your M3's rear wheels! Designed to give the best performance benefit with no sacrifices or compromises to your BMW's reliability. These have been tested on hundreds of cars before public release and there are simply NO DOWNSIDES to this upgrade. CNC machined using aircraft grade 6061 aluminum billet, and anodized with a stealthy black coating. Others may advertise "their" crank pulley boasting higher numbers (using a smaller pulley profile), but we have concluded that for street and track driven M3s, this is the best size and design to ensure proper engine temp and auxiliary functionality. As the S65 M3 V8 engine doesn't use a traditional harmonic balancer, all factory harmonics and dampening are fully and properly retained. We've found this pulley alone adds 10 to 14 HP and 7 to 9 Ft/lbs Torque on a stock M3 with no other mods(!!)." 1 Quote Share this post Link to post Share on other sites
fred_ 166 Report post Posted January 9, 2015 Bump Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
fred_ 166 Report post Posted October 14, 2018 BUMP Quote Share this post Link to post Share on other sites
