Stevie S
Bavarian Technic Scanner
Hi I have a basic Bavarian Technic cable and I am connecting to a 07 335i E91 N54. When using the program it the shows cable connected and I can access the modules in the left hand menu and read codes. But when I select Condition Based Service , it says reading vehicle data, then shows a blank screen and says data read out on the bottom left corner. I should be able to see oil lever ,brake wear etc.Your help would be appreciated.
Cheers
