richard.pykett 36 Report post Posted May 2, 2015 Dumb idea number 423... Wondering about fitting the smaller crank pulley from the M52 with the rear block mounted OBD2 crank position sensor, to the M50. There will be some gluing /welding and machining involved I know. I need an alloy block and crank to have a play with please. Guess that it could be any 6 cylinder, but need to end up with a 2.8 crank for the final build. Ideally would have the crank sensor and front pulley. Block can be stuffed. Auckland area please, cheaper the better as none of this may work. Thanks Richard Quote Share this post Link to post Share on other sites
