sven007
Window insulation I think
hi, My window insulations is coming a bit loose I think in the top right side door corner. I think its called insulation. so water does not get inside. everytime I put the window down it comes a bit loose. What is the best recommendation to fix this problem. Greatly appreciate the help! Regards Sven
So its a coupe, and its the bit right at the top which is starting into the furry interior stuff? If the seal is crappy looking, replace it. Otherwise a bit of glue should be ok - it might have lost its elasticity/hold due to age.
