Richard7666
Wtb: camshaft position sensor (secondhand, ideally)
After part 12147518628 which according to realOEM was basically used in everything from 98 to 06.
Got a quote from partsword.co.nz and their price was more than a brand new Meyle one from MillAnd!! ($93)
(I don't want to spend a lot of money on this as we are not 100% sure it is the issue, hence after a secondhand)
Used sensors will often throw the same fault. $93 from MillAnd is pretty cheap, and will give you a conclusive answer.
Alternatively, have it scanned by a specialist to determine the fault.
