dkonsta1
M62 V8 oil filter housing rubber mounts replacement and improvement.
My rubber mounts on the oil filter housing were gone so I had to sort this asap. There is a high risk involved by driving the car if both mounts are gone.
The general layout is like this.
Called BMW asked for price. $90 for the set.
I said f@@k that I will check local after market ones.
Mount Shop Penrose.
In stock $40 for the set.
I chose on purpose to go one size up on size to make it bullet proof.
Original mount is 20 x 20 with M6 male studs
Problem is the bottom stud is quite short and once the rubber goes it's a hell of a job to remove it from the metal bracket.
The one I chose is 30 x 20 (larger diameter not height) with 2 long male stud M6
Benefits from the upgrade is better anti vibration, stronger Mount and easy to remove in the future just by putting a m6 cap nut to undo the worn Mount.
