RipJaws
M52 DME ews and performance options
Hi,
Need to know the quickest/easiest way to get rid of the ews on my DME. Best to buy one already done from eBay? Or try get the equipment to do it myself or buy a chip or send it to someone with the knowledge or what?
Has any one had any experience with this? It's for an m52 to e30 swap
Ok thanks for that, I'll try get 2 and send you one spare. I was meaning to ask on this for SAP and rear o2 sensor delete as well as EWS removal. Do you know if the car will still run ok with SAP and rear o2 still programmed into the ECU? If you can't remove the others its fine I'll just try my luck with an ECU having no EWS so thank for that I do appreciate it and I'll get those out to you ASAP.
