tcbaurpower 5 Report post Posted March 5, 2016 Hi All. e32 87 So the electronic display has been on the fritz for awhile and a good ole tap on the dash would set it straight. But now it has died completely and no tap is bringing it back. I searched the net and replaced some capacitors on the board to see if that was the issue. But like most internet fixes my problem does not seem to be the same, although the symptoms seem to be. The easiest solution maybe to replace the entire cluster, but can anyone advise on that? Maybe it is wiring or another module or some such thing I have no idea on. FYI the speedo and rev are still working and the computer was able to tell me how many km fuel I had left. But now the obc displays the PPPP error which is for 'no communication with instrument cluster' I believe. Cheers, Adam Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted March 5, 2016 Get it checked by an instrument repair outfit. Actually PM me for someone in CC that can check it Quote Share this post Link to post Share on other sites
