wtbdeath
Reset your adaptation
I just reseted my E46 and E90 adaptions, WOW! what a difference! now they both drives like BMW should ! smooth engine all the way to redline.
My E46 usually kinda jerkey at low rev, and the VANOS seals were bad. After replacing VANOS seals, idle was fine but still jerking a little bit, I thought it was my dual mass flywheel on it's last leg but WOW, it is engine adaption.
I was using #98 all the time, maybe the adaption was from the previouse owner driving style + bad vanos seals, I don't know, but it made a HUGE difference!
I rested via INPA.
If you are near Birkenhead and don't have tool, I can do it for you (free of charge), just drop me a line. Can do E36, E46 E90, others I will need to check as never done before.
Edit: forgot to mention I also have ICOM tool (dealer grade) , if you want your car be scanned for codes, I can do it for you (free of charge), only works if it is OBDII connector ( no E30 etc.)
Edited by wtbdeath
