Steve K-B
E28 rear hubs
Hi,
Im looking for the rear hub and inner flange off an E28. I need it to see if i can use them for my E36 compact so would take any condition at this stage.
Parts 1 and 5 in the link below.
http://www.realoem.com/bmw/enUS/showparts?id=4062-EUR-09_1982_E28_BMW_520i&diagId=33_0170#33411129859
Thanks,
Steve
i might be able to help you out.
I have two sets of arms that need new bearings so will be what you are after.
Hi steve,
I looked into this for my E30 many years ago, and the problem if I recall was a conflict with the rear shock mount and the axle flange.
That is why I dropped the whole E28 back-end in my E30 (and the improve geometry of course).
There are a few pic's around the net of some dodgy workarounds to extend the rear shock mount further rearward (might have a pic/link at home).
The other option I thought of was making some custom drive flanges from a pair of old CV's, but given the state (and small diam.) of the splines of the ones I removed, it didn't seem like a wise choice.
[edit]
The other issue I just recalled was the wheel mounting side of things ended up a long way inboard, and would need thing spacers to mount even shallow offset rotors.
[/edit]
[edit]
Found this on some Swede/Finish forum years ago, NB they've also swapped over E32/34 diff mount to the E30 subframe, seems a bit OTT given the E28 Big Case housing bolts in...
[/edit]
Edited by E30-323ti
