MattA
SOLD Molnar 2 post hoist SOLD
I have a two post Molnar hoist that needs to go. Was purchased with a mate with great intentions but priorities have changed as they do.
$250 and it yours.
Was told the cable had been replaced and ram serviced prior to me getting it, but I've no documentation, so comes with no guarantees. Can still get parts from Molnar for these (lift pads etc).
It is electric / hydraulic (ram drives the cable). Electric motor is 3-phase, you could swap out the motor for a single phase of the same hp? At some point someone has welded RHS to the posts with lock out pins so its can't drop. Will need to be picked up with a car trailer with a tilt deck and winch. We dragged it up with a hand winch without too much hassle.
As best I can find out from uncle Google, specs should be as follows;
Lifting Capacity 3000 kg
Minimum Lifting Time 27 seconds
Footprint 3250 x 1200 mm
Length 1200 mm
Overall Width 3250 mm
Height 2770 mm
Width Between Posts 2650 mm
Drive Through Width 2420 mm
Maximum Raised Height 1900 mm
Minimum Lowered Height 110 mm
Motor Power 415 V Standard (240 V Optional)
Hydraulic Oil 5 litres ( 46 Weight / High Quality / Anti-Wear)
Pack Dimensions W 4000mm x D 1200mm x H 600mm
Pack Weight 722 kg
Edited by MattA
