Chris_guy
318i Yo
Guest Andrew
ditch mtech2 wing for mtech1 wing -
clean it
lower - 15" wheels - smoked lights - full color code - iS lip.
ditch pod filter.
how much are is lips? wrecker here has told me a price but im not sure..
ive been told 290 +gst new
id rather try make one thats a tad expensive for a bit of plastic
ALso whats shadowlining i is be a noob yo
Edited by Chris_guy
not a fan of Mtech1 wing, I reckon a colour coded sport lip would be the go. Go meguiars 3 step and you should be looking a whole heap better. You dont have to ditch the pod, just put a heatshield around it. like mine...
which H&R springs are they?
mike, how did you make your heat shield?
$359+GST new ($405)
Guest Andrew
I was thinking this kinda look for his car - don't tell me that wing ain't hot
thats mean, f*ck awesome
got any details on it? what r the wheels?
umm they are 35ml h&r's , yeh also howd u make your heat sheild if you made it yourself...
im getting adjustable suspension soon if its cheap enough cuz i can get it at cost price :P brilliant and any mags i want and tyres too
might even make it a 325 i know its heaps of work but ive got time and all that so who cares
btw i work for ray(royz) if anyones seen me before
Edited by Chris_guy
Guest Andrew
then look at the heatshield in my racecar - it practically lives there (although not right now)
Guest Spargo
1989 325i
Engine: 2.8liter m20 Stroker
Block bored and decked
2.7 eta stroker crank (balanced by machine shop)
Ross Racing pistons and forged rings, 10:1 compression balanced and blue printed
Strengthened wrist pins
"i" rods (balanced by machine shop)
Brand new oil pan
Brand new head(worked)
Korman Competition Stage 1 rocker arms
Brand new oem valves
BMP 282/272 cam
BMP dual valve springs
All new gaskets, seals bearings, and oil pump
BMP silicone 8mm plug wires
19# Ford injectors
M30 big six AFM
325e metal airbox with e30 m3 bottom end
Stebro Full Stainless exhaust
Driveline: 5spd manual trans, Z4 2.5 short shift,
Light weight flywheel, Sachs Sport clutch,
Mr. MCar built e30 M3 LSD with 40% lockup
Suspension: KW 60/40 springs with Bilstein Sport Dampers, Sparco front strut bar, E46 M3 RSM's, Z3 plate enforcers
Brakes: Balo, Brembo cross drills, Pagid pads, Goodridge stainless steel lines
Wheels/Tires: 16x9" Cr7 wheels, 215/40/16 Toyo T1S tires
Exterior: Factory "iS" front lip, RyanG splitter, factory Mtech1 rear spoiler, all red tails, shadowlined trim, euro plate filler
just got a an offcut piece off metal, cut it to size and bent it to shape using a folder. Cut/Drilled holes in the right places for AFM and thats it, not much to it at all really. Having the right tools for sheetmetal helps :D
I was thinking about making a few up and selling on here/tardme etc but couldn't be bothered with different style intakes and all the other bullshit that goes along with it.
andy, I just don't dig tec1 wing.
i is bin finking all dae yo. might sell or swap my mtech spoiler is anyone one keen for a swap for a mtech one?
or how much could i sell it for??
will do andrew thats my next mod then maybe advanti essens not sure though mags are a hard choice
thanks for posting those pics, awesome car porn
also how much do u reckon it would cost to build an engine like the one is the car picd above? also any idea of power output??
Edited by Chris_guy
