jivismokin 1 Report post Posted April 19, 2017 Hi All. Need someone who knows how to code out errors to remove a "Adaptive Headlights failure" error that is popping up. Happened after I changed the headlights to a different one. I know the reason why it is coming up but just wondering if anyone can help with coding the error out. Was looking at NCS Expert but it is too confusing for me Quote Share this post Link to post Share on other sites
Onizukachan 5 Report post Posted May 20, 2017 Add NCS for dummies. Once yup have the trace for the module, go to Dummies, pull the same module, and point it af the trace. Everything will be in semi plain English. Find the settign ting and change it, then save the modded trace, go back to NCS and so codeiren, and done. Basiccally you access the module and wrote the changes with NCS, but actually DO the change on Dummies. Hope that helps. A year or so ago I was starting from zip knowledge as well. Now I can't explain it that well because it's all just instinct, lol. Quote Share this post Link to post Share on other sites
