my_e36
Engine stalls itself...
e36 323i auto, diagnostics code read by BM Workshop
just the 2 parts alone cost well over $800
plus labour!
joy o joy~
symptoms: stalls itself 3-5 sec after stopping, in D-gear rev doesn't change when air-con kicks in, hesitation when try to accelerate at around 2000rpm
no code on O2 sensor or AFM
Fixed! New Idle Control Valve and Cam sensors (pulse generators)
Idle is now solid as a rock.
The engine is quieter too (don't know why, but it's good)
Throttle control on light pressure is back, there's no more hesistation problem.
Seems to use less fuel according to the fuel consumption meter on dash.
It's off the end of the scale at 60km in 4th gear (5 speed auto) without pressing on the throttle.
Edited by my_e36
