E30-323ti
FS: Holset HX35
Due to financial commitments I have to let this beastie go :(
As stated it is a Brand New Holset HX35 with a 12cm T4 Euro turbine housing (no wastegate), 4" inlet, 2.5" outlet on the compressor housing, 3" V-band outlet on the turbine housing.
I researched for months before deciding on this turbo, my criteria was:
Quick spool up (~3000rpm)
High effiency
easy 400rwhp
It was to be fitted to a 2.5l engine so would be suitable for a 2.3l to 2.7l M20.
I'm wanting $1600 for it, this is ~$300 less than the holset NZ distributor could do it for before you go bothering them with silly questions and is a bit less than what I paid to get it here from the US.
There are many compressor & turbine(and hsg sizes) upgrades & rebuild kits available cheaply from the Holset distributor.
PM me if you have any queries.
holset_hx_35.pdf
Here is the compressor map for it.
I have marked out for 15 and 20psi (what I was planning on running) for a DOHC 2.5l engine.
The lines won't extend as far to the right for a M20 of the same size due to the lower Volumetric Efficiency, but will be pretty similar.
Edited by E30-323ti
dayum...awesomeness. holset has an NZ distributor? contact details? just for future reference :D
Can't remember their name, they are in Nelson, they also do schwitzer & KKK
They aren't much use except for rebuilds (which are cheap as) etc... as the NZ market didn't get many of the trucks with the "Kewl" turbo's the swed's etc... like to use, so they are all special order.
The HX35 for example was going to be close to $1900 and 3 months ex.UK
Fook, that.
You should just buy mine now and be done with it Gus :)
