Danny Kiwi
May have Dead 535i
I have an Idea that my M30 535i is Kaput!!!!
It,s making one hell of a noise and now the starter wont even turn it over..
does anyone know where i can get a reasonably priced second hand replacement??
Have you had a mechanic look at it....most things are fixable, and it might save you having to buy a replacement car.
I'm sure it isn't as bad as you think.
Good luck anyway.
Cheers
Yes I think he may...
No afraid its a case of broken timing chains,I am almost sure of that,.. and Valves kissing Pistons and bending and all those sort of things ...Shock Horror Probe..
If anyone has any 535iM30 Heads let us know..Boo Hoo Hoo...
Guest Andrew
get a new motor then. M30 shouldn't be too hard to find.... OR did i hear you whisper M5... ? heh
I didn't realise the M30 used chains? Amazing they broke!
The tensioner could have failed and then the timing chain could skip a tooth or three...
Not good though.
Ring around and see if you can find another engine.
Specialised in upper hutt had a few E28's last time I was there, BUT, the guy is a complete W@NKER and I'm not going to buy anything of him again!!!
Yes I find him and unusual Chap...dont quite know how to take him..and his staff always look grumpy or unhappy..
Ill give P a Call..
Thanks for the Tip man..any idea on what sort of price??
I wouldn't pay more than $800-1000, and it should be complete, ie: unplug yours plug the new one in!!
But it is a BMW so you never know!!
He has an E34..3 Litre Motor that he says is quite good..for around that price...
I would prefer the 3500..
BTW Update!!!! It,s not the chains..Took us about a couple of hours to get the Radiator and all the Front Gear off, and the Chains look ok..But!!!Broken number 1 Rocker Arm..and the bottom end will not turn over still...something is siezed...
Its No. I Piston too I am sure, so may have a bent Rod!!
Will keep you posted and thanks for all your input ..its appreciated.
Its a nice Old car!!Leather,Air Con ..Electric Seats, Sunroof ect ect..
Would hate to have to wreck it!!
