Ahtwoniceuh 1 Report post Posted February 9, 2018 as per title. 5x120 believe they are off a 5 series originally but were fitted to a e38 last $500 may trade for m20 parts located in wellington central drop off negotiable Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 9, 2018 do you know what the centre bore diameter is? It is likely to be either 74.1 or 72.6 (or thereabouts).Most bmw 5 and 7 series are the 72 mm but the e39 5 series was 74.1.Hence a lot of aftermarket BMW wheels are 74.1,which means there is a SHIM(i cant remember the proper term) to suit the 72 mm fitment Quote Share this post Link to post Share on other sites
