Rocketman 0 Report post Posted July 7, 2018 Hey all Does anybody have an abs module for the above. Number on the pump is 34.51-6 750 383. Does anybody know a crossover part number? That can be coded to car? Any help would be much appreciated. Cheers Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted July 7, 2018 Your research may have told you that these are prone to failure with age, due to repeated heat cycles. They can sometimes be repaired. AutoStop in Tauranga can do this but new modules are also available at reasonable prices and might be a better long term solution. I have had experience of having the repair done and have also bought a new module from overseas and had it coded here in NZ. Both solved the problem I had (yellow light trifecta). Have a look at http://www.maf-shop.com/ to get an idea on a new one. These guys are great to deal with and postage was cheap and fast. A new one will need coding to the car, and a second hand one might need recoding, whereas a repair of your module will not need recoding. Quote Share this post Link to post Share on other sites
