Paragon 14 Report post Posted October 4, 2018 Time for a clean out. Generally M20B25 unless stated otherwise. Starting with the bigger stuff: 2.0 litre 731 head. Legal for race series. Hardness tested and straight Valves and valve springs 2.0 and 2.5 Camshafts M20 2.5 block. Bores still have hone marks $100 2.7 crank, may need a grind, marked on one big end my measurements 44.69, 44.72, 44.72 / 59.73, 59.66, 59.65, 59.64 59.77 59.66 $100 2.5 Crank H75 does not need a grind, 59.95 and 44.94 $100 rods, 135mm ( 2.5 ) injectors , M20B25 520i, 325 and 320 exhaust manifold, 3 bolt other small stuff like rocker shafts Bearings, King for standard crank mains and big ends, fits 2.0, 2.5, 2.7 $100 all in south auckland Quote Share this post Link to post Share on other sites
