Jacobfie525
E34 Wheels
I'm After The Wheel Offset And Stud Pattern For E34 5 Series BMW's.. Looking At Getting Some Wheels For Mine.
Anyone Know?
Apparently The Largest Size That Will Fit On Without Modification Is A 19x9.5 But I'm Not Sure Of What Offset Or Stud Pattern The E34 Is.. I Believe Its A 5x114.3?
If you take one of your wheels off, it should tell you everything you need to know on the inside of the wheel. It might even be underneath the center cap if you have one.
Assuming that you have BMW wheels on of course !
Failing that its amazing what Google can find for you ;)
For the E34 Stock is:
Off set ET20
PCD 120mmx5 (120mm pattern)
Hub center 72.5mm
Mine are ET19 16x7inch with 245/45/16 no rubbing.
Not quite 19x9.5's I know!
Look at some of the M5's with staggered wheel setups; this would give you a good indication of how big you can comfortably go, and if the ET's change, if at all.
19 may be a little big for the e34,the latest e 34 came with 18,s
there is some info at the useful E34.net
I may have some less than perfect 17 x8 Et 20 74mm bore wheels for sale soon
Posted Image
Edited by kiwi535
Might Be Interested In Those 17's.. Or Tracking Down Some M5 Wheels.. Or The 18's.
As For New Wheels. I Was Shown A Pair Of 19x9" TSW's At Magwarehouse That Apparently Fit.
Bit Too Over The Top Full-Face Chrome For Me Though, I'm More After A Controlled Classy Look Instead Of The "I'm Trying To Whack As Much Chrome As Possible On My Car To Attract Girls" Look.. Because Thats Too Close To The "I've Got LED Tyre Caps, LED Windscreen Nozzles, LED Exhaust Tips, LED Shift Knobs But I'm Really Just Compensating For My LED Sized Penis" Look.
And The Only Thing Worse Than That Is Driving A Honda
Good luck with that.I have been on the lookout for some throwing stars for ages.Be careful with aftermarket wheels.Make sure you get some strong ones,the e 34 isnt light.Most aftermarkey wheels will require 74>72.5 hubcentric rings
Set On Trademe Again Now. Wonder If They'll Go For Below 2 Grand..
