Jonesee
1983 323i E30 - Need Help
Hi Team,
Have a few issues with the E30 I picked up recently - I've taken some photos to help.
  • I've got a decent oil leak coming from somewhere high up (based on the coverage of oil over parts quite high up in engine bay)
    • The plug underneath the Throttle has oil all over it - unsure how, but this is the highest part of the engine with much oil over it
    • When the engine is running, I can't see any obvious leaks (it isn't spraying or gushing out of anywhere)
    • See image of throttle and plug below it
    • I've also heard there can often be leaks from the 'Bitch Tube' or 'Tube of Death' as some people call it? The one with the spring on it. Could be a culprit?
  • I've also got a decent coolant leak
    • Again, when running the engine, it isn't gushing out of anywhere - at the bottom of the radiator (see image) it seems to be gathering and it drips from there
    • If it needs replacing - does anyone have a good recommendation of brand/model/type to use? (anything to avoid)
    • At the Coolant reservoir, the tube is cracked (as image shows) - can anyone recommend where to get a replacement?
  • Also, tube coming out of the valve cover (oil return?) appears to be cracked - so should probably replace?
  • And finally, on throttle there are tubes going in on each side, which aren't 'fixed' in place and can easily fall out - I've seen some people 'jb weld' these in place? Any recommendations
Appreciate any help you guys and gals can offer
20190224_143905.thumb.jpg.e29c5704cd6d54d6dc39f20fc05edc88.jpg20190224_143728.thumb.jpg.e94ea2db0e0bbedd021c6540dddc7b39.jpg20190224_153908.thumb.jpg.09cf9384511770b987dbb8d940f925c3.jpg20190224_161437.thumb.jpg.fd94d7ed64394457c39961941c1e22d6.jpg20190224_161445.thumb.jpg.c31316c0292c75517916eb3287eff7dc.jpg
