Bruce 1234
e39 rust under front carpet
Hi.
I had the carpet out of my E39 and found the rust pictured in the left front footwell. While getting the carpet and centre console out took a couple of hours it was worth doing just to find this before it turned into something worse. I ended up cutting my carpet where it goes under the middle dash support - went back in fine - the thickness of the carpet seems to hold it in place ok. I was going to use some double sided tape but proved not necessary.
