Paragon
M20 engine parts
Various M20 engine parts,  - edited
crankshaft  2.7 H81 GGG700 $150
crankshaft  2.5 H75 GGG700 $100
885 head, vapour blasted, hardness tested, pressure tested, straight, with valves / springs / collets/ rockers $900
Short block rotating assembly 2.5, taken out due to worn rings $300. Good bores.
Camshafts, 2.0 and 2.5, no wear $40 each
Rods 135mm, not sure of origin, may be M50 engine $100 set
Rods, 135mm not sure of origin, probably 2.0 litre $60 set
Rocker cover dirty $30
Rocker cover vapour blasted clean $120
Bearings  main  standard - check part number  King MB7039AM $100
Bearings  big ends standard - check part number  King CR6640CP  $80
fuel rail, 325, $20
engine mounts vapour blasted $100 pair
front cover, 2 pieces vapour blasted $60
main seal vapour blasted $40
inlet manifold vapour blasted  $120
ECUs, 325 pfl 0261 200 073,   facelift 0261 200 173  chipped for BTB exhaust,   320 facelift 0261 200 172,
AFM for 320i, off SA spec car, 0280 202 093, ran ok $60
collect from  south auckland, some parts can be delivered by courier.
Edited by Paragon
sold some parts
Have PM’d you
