cat007 0 Report post Posted February 17, 2020 Hi all, I have an issue that has popped up randomly in the past 2 weeks. I will be driving along normally, on a reasonably flat road, and the low oil light will come on. When I pull over to check the oil, it says it's low and to add 1L. After another 2 or so minutes of driving I check again, and it's full. And ever since then, it is showing as full still. I'm not burning/using/dropping oil, so I don't believe it to actually be low. Is the oil level sensor something that is a common fault on these? Cheers Hunt Quote Share this post Link to post Share on other sites
