nz320i 0 Report post Posted April 15, 2006 (edited) think its time to spend up.. car makes crazy sounds like knocking when braking, drving and changing gear in the rear left. CV boot been split for abour 2 months without me knowing so i guess its that? I need CV Boot or joint - will contact you bout this Brent Will get a new boot anyway Rear Subframe Bushes ( How much are these? ) C arm Bushes (was told $115 from BNT !! ) Sway bar linkages (universal fron BNT $30 a side sound ok? ) Should i fix anything else while i do this work and is it easy to do? i got a socket set and two axle stands Holla Edited April 15, 2006 by nz320i Quote Share this post Link to post Share on other sites
petone 0 Report post Posted April 15, 2006 (edited) www.bmw2002.com get trailing arm bushes, subframe bushings, and see what they got for CABs. Thats where I got all my stuff. Cheaper than rubber replacements and make a huge difference if you current bushings are f**ked. You're gonna have some fun replacing that lot with a socket set. its not hard, just make sure you got the right gear. Edited April 15, 2006 by petone Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted April 15, 2006 how much did it cost you all up? do i get the m3 offset CAb bushes? its all i can find? Was shipping expensive? thanks Quote Share this post Link to post Share on other sites
