M3_Power
FS - Karbonius M3 CSL carbon door panel inserts
Used Karbonius CSL carbon door panel inserts in 1x1 carbon weave.
I can honestly say these are as good if not better than the genuine article. Perfect fitment and weave pattern and stronger construction than the real thing.
Made of Prepreg carbon vacuum packed and autoclave cured. Very strong.
***BARE CARBON DOOR INSERT PANELS ONLY ***
****NO door handles or door cards included****
NO mounting hardware included***
 - ALL YOU GET ARE THE CARBON PANEL INSERTS WITHOUT THE GENUINE CSL DOOR HANDLES SEEN IN THE PHOTOS****
The weave on these are so good that if you placed a genuine CSL door panel next to it you would struggle to tell them apart - see last photo illustrating this.
These are not off the shelf items and are made to order only from karbonius. Very rare.
Genuine CSL door panels are $8000 EACH!! So it?s $32,000 just for the door panels - And they are basically NO LONGER AVAILABLE.
$3000 firm.
Compared to the genuine csl panel (front bare panel pictured below is a really old genuine csl carbon door panel - has slight yellowing already) as you can see the Karbonius (the rear panel - top one) is a perfect match
  • Like 1
