Gus 5 Report post Posted May 3, 2006 underneath an exhaust shielding panel? i DID hear it 2nd hand...hopefully there's none! Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted May 3, 2006 as for Hp...after actually driven a 318 5 spd, you appreciate the lack of weight up front..would almost be a shame to lose that! Quote Share this post Link to post Share on other sites
pussytamer 0 Report post Posted May 3, 2006 Nah your right, it appears that it's common issue with the E30's that under the heat shield right at the back by the bolt hole, they rust around the stud. Not a biggie, about the size of a 20 cent piece, rust killed it and put a rubber grommit in it.. until I fix it properly. Now it has the Z3 Steering Rack in, it's arwsome :mosh: Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted May 3, 2006 Conrod I'm with you on the $$$ for HP, it would be cheaper for me to buy that motor than spending huge $$ on s14 to the same level of HP. Wayne This is prolly the only area I'd be a BMW purist, It's just not a e30 m3 without a S14.Turbo it (does loose some of the originality of the m3) if need be to get some usable HP out of it instead of a mega $$$ rev happy NA build or a big heavy S50. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted May 4, 2006 Nah your right, it appears that it's common issue with the E30's that under the heat shield right at the back by the bolt hole, they rust around the stud. Not a biggie, about the size of a 20 cent piece, rust killed it and put a rubber grommit in it.. until I fix it properly. Now it has the Z3 Steering Rack in, it's arwsome :mosh: Z3 rack sounds awesome - you coming to taupo?Turbo S14 is my dream turbo car. Quote Share this post Link to post Share on other sites
pussytamer 0 Report post Posted May 4, 2006 Andrew Yep on the road around 9.30am tomorrow Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted May 4, 2006 see ya down there - we (gus and I) are helping out with driver training so i'll jump in the car with you at some point. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted May 4, 2006 Turbo S14 is my dream turbo car oh really! how conveniant! damn i am persuasive Quote Share this post Link to post Share on other sites
