Guest bridgeport Report post Posted February 24, 2004 yeah basicly as the title sez i need an engine as long as its running sweet must be cheapish in auckland may travel further depending contact me on 09 4735062 peace Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted February 24, 2004 Can't be that expensive to do the gasket - diy.. m10 looks pretty easy to work on. Quote Share this post Link to post Share on other sites
Guest bridgeport Report post Posted February 24, 2004 girlfriends dad warped the head driving back from the testing station i will see how it goes today hopefully duznt over heat to bad it gets hotish if ya leave it sitting for ages hopefully when i drive it temp should go down i think the water pump was the start of the problem thermostat is $95 because its built into a t pipe and you have to replace the pipe with the thermostat inside just makes life easyer to slot in a new engine than messs around with whats there at the moment it has no themostat peace Quote Share this post Link to post Share on other sites
Guest bridgeport Report post Posted February 24, 2004 decidedto go do the headgaskit repco appco and partmaster dont have them so looks like bmw is where i have to get one from looks like its gunna be expensive or if i find a m10 ill buy it peace Quote Share this post Link to post Share on other sites
