Dooooa10
N13 cat delete scan help
So I got a n13 cheap I straight pipe 2inch from a catless down pipe an a engine light 💡 has come on anyone in Christchurch able to scan for Sunday’s beers cheers
Edited by Dooooa10
You will need to get the DME reprogrammed by a ECU repairer or specialist to remove the engine light.  BMW won't be able to do it fyi.
Cheers for the info it’s had a ecu upgrade from the 116 to a 120i by autoupgradesnz
