danutt
cams!!...sum help
was told camshaft is worn so im going to replace it with a racing one pref so wat to get??
car is a daily driver but at the same time not really bothered so id like a lil gain at the same time:)
so any sites i could visit to aquire one or does someone here have a contact to get them fitted etc
all info bout gains and wat you noticed in your experience and also opinions regarding cam shafts
thanx :mosh:
well... get a second opinion. if camshaft is worn then rockers will be aswell.
I'm not sure how much work is inlolved on m10.... but quite alot on m20....
could have had the same text in other posts lol im just eager to get it sorted...if the camshaft is worn yip the rockers will be too ..i have an m40?318i so i just need a lil help wit a recomended cam replacement etc
thanx
my recomendation:
it will be cheaper to buy the same engine off trademe than rebuild yours....
camshaft is likely to be ~US$200+ shipping from US, and set of rockeds... i dunno, you would have to check. since you will be doing that you will need aswell all head seals, most likely inclusing new headgasket and new headbolts. (read another ~NZ$300-$400).
now thats if you do the job yourslef. expect several hundred NZ$ from a reputable workshop for labour...
for $500 you should be able to fuins a decent 318 engine on trademe.... possibly even 318 IS engine....
got incontact with franklin cams having one made for $420
and gonna get labour and rockers replaced by my friend at bmw so its all go cant wait
rather not take the motor out coz i cant put one in and having that done will cost alot and also just fitted gearbox bout a month ago and hell no im not doing that again
will make a post once work is done
