atozav
540i TV/DVD
Hey there people, this is a bit of a long shot i know, but does any one know how to (Colour codes ans location) hook up an exturnal AV source, ie DVD, into the factory TV monito in the dash of my 540i ??
Jochen will know.E-mail him
Hi,
For the benefit of all I'll answer here.
Yes, it is possible and it is very easy.
As long as you have the TV tuner on your Bordmonitor - which you'll recognise by the fact that you can receive TV - then you have an AV input which you can connect any standard video source too.
So you can connect a DVD player or a Playstation or X-Box or your digital camera or whatever.
The TV Tuner actually has 2 x extra video inputs.
1. The AV input I've mentioned above
2. A Reverse Camera input, which, when active, has priority display on the monitor.
Both are easy to wire up, either by
a) fitting new pins to the connectors on the TV tuner and wiring in new RCA sockets on a short lead
B) fitting RCA sockets on a short lead to the circuit board inside the TV tuner
c) buying a special adapter cable so everything is plug and play on to the TV tuner
It just so happens I've got some of these adapter cables coming from Germany, should be here in a few days.
If anyone wants to hook up an AV input to their Bordmonitor, then I'm happy to help.
Cheers, Jochen
Edited by jochen
Any more Nav system or Monitor Qs, ask away :-)
Edited by jochen
