logix 0 Report post Posted June 24, 2006 Hi. Just got a mint 328i E36. Im looking for ideas on what to do to it to get more response and overall power out of it. Ive done exhaust and intake but would like to look at smaller options before super chargers and turbos. If I take anyone up on there ideas Ill let them know and keep in touch with the work as it happens. Any recommendationsd of performance tuners on BMW's in Auckland that can handle ECU configurations or replacements..... Thanks for the help. logix Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted June 24, 2006 First of all, welcome... Have you check if the maintenance is up to date? Air filter (K&N panel is great) and fuel filter Fresh diff fluid (Make sure you can open the fill hole before you drain the old stuff out!!) Spark plugs (You can also change valve cover gasket as preventative maintenance, since you need to remove spark plugs before you can change the gasket) Run a bottle of injector cleaner and on 98 Octane fuel helps a lot too! These all help response and fuel consumptions. Quote Share this post Link to post Share on other sites
logix 0 Report post Posted June 25, 2006 cool...ill do those things...I have had the cats removed. Should i get a tune done on a dyno. Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted June 25, 2006 Call Robin at Torque Performance, as they have a dyno day once a month for $50 for 2WD. A little extra will get the Air/Fuel ratio done too. Cheers and Welcome Quote Share this post Link to post Share on other sites
