ducatiss
Stalling Auto
When selecting reverse or drive when the car is cold the rpms drop to about 500 and the car is almost stalling. If you raise the idle speed to where this doesnt happen, when the car warms up the idle is then at 12-1300 rpm. I pulled out the idle control valve (this is an L-Jet with the water heated idle valve) and as it was stuffed replaced it with a good one which I have tested. Problem is, there has been no difference at all on cold starts. I have checked right through for air leaks and it seems fine. Car drives well otherwise. Any ideas? - Anyone?
Edited by ducatiss
