sadida20
e36 lights
I have just purchased a 97 323i
On the dash where you turn the lights on should that glow when lights on OR remain dark and hard to see?
thanks
Edited by sadida20
yeah i know that
But the part where you turn ther lights on does that light up?
"But the part where you turn ther lights on" is called the headlight switch and yes, it is normally illuminated at night time.
You may have a blown illumination bulb, remove the switch and check the bulb
Jochen
Edited by jochen
Did you mean the light switch? It does light up when the key is in position I or II regardless of the lights are on or not.
To remove the switch...
1. Remove the panel below the steering wheel
2. Remove the know (pull it straight out, it helps if you put double-sided celo-tape on the knob)
3. Remove the plastic nut that hold on to the switch
4. It pretty much drops off from the back.
Edited by my_e36
