sadida20
bulbs
Hi Guys
can anyone tell me if its easy to replace blown bulbs in E36 headlights ?
if so how?
Thanks
Space is a bit tight, but should not be too bad. Which bulb is blown?
For turn signal, you need to take the turn signal housing out (it just clips onto the headlight housing).
For the rest, there's a plastic cover on the back. Take it off then you can see all the bulbs retaining clips and wires.
