smokey
e30 ecu and clutch
hey i was just wondering im just stripping down a 4 door e30 for the motor and manual box, as im doing a conversion and i was wondering where abouts is the ecu ?? and it has an hydrolic clutch so will there be a clutch master cyclinder as well ?? cheers David.
ECU is above and forward to the drivers right hand knee...take off the underdash panel and you will see it
the MC is attached to the pedal box...take the whole thing out, be sure to disconnect the brake bar that goes across the firewall to the brake booster and get it out the way, then take the whole pedal box out.
