Huttey 0 Report post Posted July 29, 2006 Has anyone any knowledge in deciphering the trouble codes you can obtain through Test 14 in the OBC, I performed this test and got the following readout: DIAG 1 F5 84 000 DIAG 2 BF 88 021 DIAG 3 8B 82 000 DIAG 4 92 82 000 DIAG 5 91 82 000 In advance, thanks for any assistance Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted July 30, 2006 Here's one found on the 'net:: 92 EVAP capillary leak (0.5mm) detected "The evap reading relate to a leak in the closed loop fuel system and I would first check around your fuel tank area to see of something is lose. I would also check your gas cap to make sure it is tight and on correctly." See here for more info on other codes: http://ackthud.com/shawnfogg/faultcodes.htm Haven't checked to see how valid these codes are for your car, worth looking though You have to zoom in and enhance the picture to see the fault code numbers, but you can do it Jochen Quote Share this post Link to post Share on other sites
