savvi
painting interior help
can anyone tell me what paint to use on interior,eg. console,instrument panels and should i put down a primer first, cause my first attempt saw it starting 2 form little circles were the paint wouldnt stick any help would b great
:blink:
OK mate, What you do is :
(1) Clean the product with 'Wax & Grease' remover that car painters use [it's very safe on most vinyls etc]
(2) Soak the product [to be painted] with M E K [Methylethylketone], dont rub in to hard,as this sh*t disolves vinyl [gets you wasted as well]
(3) Paint the product [any vinyl paint aerosol will do], it will need 48 hours to dry right through [vinyl paint uses M E K as an propelllant]
I have painted vinyl with this method before, and seen the new colour soak right through the vinyl
Hope this helps KERRY
