savvi 0 Report post Posted August 8, 2006 can anyone tell me what paint to use on interior,eg. console,instrument panels and should i put down a primer first, cause my first attempt saw it starting 2 form little circles were the paint wouldnt stick any help would b great Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted August 8, 2006 OK mate, What you do is : (1) Clean the product with 'Wax & Grease' remover that car painters use [it's very safe on most vinyls etc] (2) Soak the product [to be painted] with M E K [Methylethylketone], dont rub in to hard,as this sh*t disolves vinyl [gets you wasted as well] (3) Paint the product [any vinyl paint aerosol will do], it will need 48 hours to dry right through [vinyl paint uses M E K as an propelllant] I have painted vinyl with this method before, and seen the new colour soak right through the vinyl Hope this helps KERRY Quote Share this post Link to post Share on other sites
